m4 trouble
Andrei Chichak
groups at chichak.ca
Mon Sep 21 16:58:09 UTC 2009
I had just installed the latest tools and found a similar issue.
The link on the installers page is no longer correct, but you can
eventually download the tarball for m4-1.4.13-1.
On the web page it says to:
cd /
then extract the files from the tarball, which will put m4 into /bin.
If you "echo $PATH" you should have /bin in the path.
So, either your path is smashed or you didn't put m4 into the proper
directory because you didn't do the cd before the tar extract.
Andrei
On 2009-September-21, at 9:55 AM, Konstantin Volkov wrote:
> hello.
> I got trouble with RTEMS tool instalation (windows http://wiki.rtems.org/wiki/index.php/MinGW_Tools_for_Windows
> after all steps with wingw, msys, dtk, m4.
> i added PATH
> PATH=C:\msys\1.0\bin;%PATH%
> and chack it.
> But erroe happens in RTEMS tool instalation step:
> please help. What is wrrong with PATH to m4?
> life is good.
> Konstantin
> life is good.
> Konstantin <at-log.txt><m4.
> troble.JPG>_______________________________________________
> rtems-users mailing list
> rtems-users at rtems.org
Andrei Chichak
Systems Developer
CBF Systems Inc.
4-038 NINT Innovation Centre
11421 Saskatchewan Drive
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
Skype: andrei.chichak
Andrei Chichak
Systems Developer
CBF Systems Inc.
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
URL: <http://lists.rtems.org/pipermail/users/attachments/20090921/e54830dc/attachment-0001.html>
