How to add a compile time configuration option to something in cpukit?
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Sep 3 11:50:17 UTC 2009
On 09/03/2009 01:41 PM, Sebastian Huber wrote:
> Ralf Corsepius wrote:
>>>> On 09/03/2009 12:18 PM, Sebastian Huber wrote:
>>>>> Hi,
>>>>> the FTP client resides in the cpukit. It can use gethostbyname() to
>>>>> obtain an
>>>>> internet address from a DNS name. The dependency on DNS adds 35k of
>>>>> code
>>>>> (THUMB op-codes). I want to add a configuration option to disable this
>>>>> feature. Can I add this with RTEMS_CPUOPT in cpukit/configure.ac?
>>>> As I repeatedly wrote, before: All -m* flags must be global (i.e. *.cfg)
>>>> What you are trying to do violates the working principles of multilibs,
>>>> so no way.
>>> Sorry now I am a little confused. What is the connection to multilibs
>>> if I can
>>> enable or disable DNS support in the FTP client?
>> Here:
>> "cpukit/configure.ac"
> So it is officially impossible to customize the cpukit via configure options?
Very oversimplified, more or less, yes.
Cpukit shares the same philosophy as "libc". Only global compile time
options are allowed (e.g. optimization levels, enabling/disabling global
features (.e.g. networking, profiling, ...), etc. ).
Per target/per bsp flags are not permitted, because they will be
non-functional in multilib'ed configurations.
Ralf
