m4 trouble
Konstantin Volkov
kv.russia at gmail.com
Mon Sep 21 17:13:59 UTC 2009
Yes, the link for mingw sourceforge page not work.
See my step:
i unzip archive m4 in c:\msys\1.0\m4-1.4.11\ automaticaly
after this i built m4 and got new m4.exe
replace m4.exe in c:\msys\1.0\bin\
and again tryed to install RTEMS
but got new error
[m4shugar.m4f] Error 1
[all-recursive] Error 1
[all] Error2
building autoconf-2.62
may be i fogot replace some m4 lib ?
URL: <http://lists.rtems.org/pipermail/users/attachments/20090921/31d4893a/attachment-0001.html>
cd /C/opt/rtems-4.9/Packages/Build
tar jxf /C/opt/rtems-4.9/Packages/Source/autoconf-2.62.tar.bz2
cd /C/opt/rtems-4.9/Packages/Build/autoconf-2.62
rm -rf mingw32-autoconf-2.62
mkdir mingw32-autoconf-2.62
cd /C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62
/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/configure --prefix=/opt/rtems-4.9
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether /bin/sh -n is known to work... yes
checking for expr... /bin/expr
checking for GNU M4 that supports accurate traces... /usr/local/bin/m4
checking how m4 supports trace files... --debugfile
checking for perl... /bin/perl
checking for emacs... no
checking for xemacs... no
checking where .elc files should go... ${datadir}/emacs/site-lisp
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for a sed that does not truncate output... /bin/sed
configure: creating ./config.status
config.status: creating tests/Makefile
config.status: creating tests/atlocal
config.status: creating man/Makefile
config.status: creating lib/emacs/Makefile
config.status: creating Makefile
config.status: creating doc/Makefile
config.status: creating lib/Makefile
config.status: creating lib/Autom4te/Makefile
config.status: creating lib/autoscan/Makefile
config.status: creating lib/m4sugar/Makefile
config.status: creating lib/autoconf/Makefile
config.status: creating lib/autotest/Makefile
config.status: creating bin/Makefile
config.status: linking /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/GNUmakefile to GNUmakefile
config.status: executing tests/atconfig commands
make
make all-recursive
make[1]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62'
Making all in bin
make[2]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/bin'
rm -f autom4te autom4te.tmp
srcdir=''; \
test -f ./autom4te.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autom4te.in; do not edit by hand.|g' ${srcdir}autom4te.in >autom4te.tmp
chmod +x autom4te.tmp
chmod a-w autom4te.tmp
mv autom4te.tmp autom4te
cd ../lib && make autom4te.cfg
make[3]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib'
rm -f autom4te.cfg autom4te.tmp
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@AWK[@]|gawk|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/lib/autom4te.in >autom4te.tmp
mv autom4te.tmp autom4te.cfg
make[3]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib'
cd ../lib/m4sugar && make version.m4
make[3]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib/m4sugar'
echo '# This file is part of -*- Autoconf -*-.' && \
echo '# Version of Autoconf.' && \
echo '# Copyright (C) 1999, 2000, 2001, 2002, 2006, 2007' && \
echo '# Free Software Foundation, Inc.' && \
echo &&\
echo 'm4_define([m4_PACKAGE_NAME], [GNU Autoconf])' && \
echo 'm4_define([m4_PACKAGE_TARNAME], [autoconf])' && \
echo 'm4_define([m4_PACKAGE_VERSION], [2.62])' && \
echo 'm4_define([m4_PACKAGE_STRING], [GNU Autoconf 2.62])' && \
echo 'm4_define([m4_PACKAGE_BUGREPORT], [bug-autoconf at gnu.org])'; \
} > version.m4-t
mv version.m4-t version.m4
make[3]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib/m4sugar'
autom4te_perllibdir='/C/opt/rtems-4.9/Packages/Build/autoconf-2.62'/lib AUTOM4TE_CFG='../lib/autom4te.cfg' ../bin/autom4te -B '..'/lib -B '/C/opt/rtems-4.9/Packages/Build/autoconf-2.62'/lib --language M4sh --cache '' --melt /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/autoconf.as -o autoconf.in
rm -f autoconf autoconf.tmp
srcdir=''; \
test -f ./autoconf.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoconf.in; do not edit by hand.|g' ${srcdir}autoconf.in >autoconf.tmp
chmod +x autoconf.tmp
chmod a-w autoconf.tmp
mv autoconf.tmp autoconf
rm -f autoheader autoheader.tmp
srcdir=''; \
test -f ./autoheader.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoheader.in; do not edit by hand.|g' ${srcdir}autoheader.in >autoheader.tmp
chmod +x autoheader.tmp
chmod a-w autoheader.tmp
mv autoheader.tmp autoheader
rm -f autoreconf autoreconf.tmp
srcdir=''; \
test -f ./autoreconf.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoreconf.in; do not edit by hand.|g' ${srcdir}autoreconf.in >autoreconf.tmp
chmod +x autoreconf.tmp
chmod a-w autoreconf.tmp
mv autoreconf.tmp autoreconf
rm -f ifnames ifnames.tmp
srcdir=''; \
test -f ./ifnames.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from ifnames.in; do not edit by hand.|g' ${srcdir}ifnames.in >ifnames.tmp
chmod +x ifnames.tmp
chmod a-w ifnames.tmp
mv ifnames.tmp ifnames
rm -f autoscan autoscan.tmp
srcdir=''; \
test -f ./autoscan.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoscan.in; do not edit by hand.|g' ${srcdir}autoscan.in >autoscan.tmp
chmod +x autoscan.tmp
chmod a-w autoscan.tmp
mv autoscan.tmp autoscan
rm -f autoupdate autoupdate.tmp
srcdir=''; \
test -f ./autoupdate.in || srcdir=/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/bin/; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/bin/perl|g' -e 's|@bindir[@]|/opt/rtems-4.9/bin|g' -e 's|@datadir[@]|/opt/rtems-4.9/share/autoconf|g' -e 's|@prefix[@]|/opt/rtems-4.9|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/local/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' /C/opt/rtems-4.9/Packages/Build/autoconf-2.62/ChangeLog`'|g' -e 's|@VERSION[@]|2.62|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoupdate.in; do not edit by hand.|g' ${srcdir}autoupdate.in >autoupdate.tmp
chmod +x autoupdate.tmp
chmod a-w autoupdate.tmp
mv autoupdate.tmp autoupdate
make[2]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/bin'
Making all in .
make[2]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62'
Making all in lib
make[2]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib'
Making all in Autom4te
make[3]: Entering directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib/Autom4te'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib/Autom4te'
Making all in m4sugar
autom4te_perllibdir='/C/opt/rtems-4.9/Packages/Build/autoconf-2.62'/lib AUTOM4TE_CFG='../../lib/autom4te.cfg' ../../bin/autom4te -B '../..'/lib -B '/C/opt/rtems-4.9/Packages/Build/autoconf-2.62'/lib \
--language=m4sugar \
--freeze \
--output=m4sugar.m4f
make[2]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62/lib'
make[1]: Leaving directory `/C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62'
