Porting RTEMS to an Freescale MC9328MX21 with ARM926EJ-S based chip
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Sep 26 13:14:28 UTC 2009
xu ray wrote:
> I think you might want to check CSB336 in ARM BSP dir first.
> The old CSB336 is design for MC9328MXL, it would be very similar with
> the MC9328MX21. A quick and dirty way for you would be changing csb336
> directly.
> Be sure to change the csb336.cfg in make dir for the arm926ej.
> (although the binary code might be the same with arm920t)
Thanks Xu!
In this case, you are looking at a "bsp variant". A couple of
variant examples:
+ gen5200 has a number
+ csb337 has csb637
There is an autoconf macro in rtems/aclocal which says which
alternate names are acceptable.
This would leave you just looking for differences between the
csb336 and your BSP. The differences are likely subtle and
again MicroMonitor source is known to work so a good reference.
But a basic BSP isn't that hard given working source as a reference.
--joel
> 2009/9/26 Pablo Salinas <psalinas.bomfim at gmail.com
> <mailto:psalinas.bomfim at gmail.com>>
> Hello there,
> Me and a couple of classmates are looking for a
> good Embedded Systems Design class project. One project idea is to
> port some RTOS into the board and cpu used in class.
> We use a TLL 6219 in-house Board with an ARM 926EJ-S
> <http://www.arm.com/products/CPUs/ARM926EJ-S.html> CPU inside a
> MC9328MX21 chipset. The project should be finished by the first
> week of December, therefore we have roughly 2 months and a half to
> work and finish it. All three of us have other assignments,
> therefore we wouldn't like to invest all our time in this project.
> Anyway, I was wondering if any of you guys had experienced porting
> RTEMS into ARM based Boards. Currently, the board uses ARM
> Embedded Linux <http://www.arm.com/products/os/linux.html> as the
> non-RTOS, and MicroMonitor
> <http://microcross.com/html/micromonitor.html> as the Boot Loader.
> We all are very knowledgeable of C programming and have good
> background in Computer Architecture. So, to all of you that had
> ported RTEMS to an ARM architecture, how feasible do you think
> this project is? We don't care about having full OS functionality,
> just the minimum (Process Scheduling, Memory Management, etc) with
> a basic user interface that would allow to run a simple
> application that would show that actually the OS is real-time.
> Thank you, any feedback is appreciated.
> best regards,
> Pablo Salinas
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> Thanks & Best Regards!
> Ray, Xu
