erc32/sis console driver
Tiemen Schut
T.Schut at sron.nl
Fri Apr 23 13:10:23 UTC 2010
Excuse me for the list-spam.
This should be the last fix to the erc32 console driver for the time being. This time I included the changed Makefile.am, and fixed the prototype of the erc32_console_initialize function. Note that if you use these files, you can remove c/lib/libbsp/sparc/erc32/console/console.c, as it is replaced by erc32_console.c.
Since I'm working with rtems4.9.2 it is difficult to create a patch, however, Sebastian said he'd do that, which is much appreciated.
Regards,
Tiemen Schut
>>> On 4/23/2010 at 14:29, in message <4BD1AEDB020000520000FC52 at pluto.sron.nl>,
"Tiemen Schut" <T.Schut at sron.nl> wrote:
> Dear list,
> I've fixed another bug in the console drivers. I'm not sure about the
> correctness of this fix, but it solves my problems. If anyone has a better
> suggestion, be my guest.
> It turned out that in at least some cases (don't really understand when),
> console_isr_x would receive no more bytes than CONSOLE_BUF_SIZE, because the
> interrupt was cleared if the result of termios_dequeue_characters was 0, even
> if there was more data to receive (but no to transmit). I've fixed this by
> only clearing the interrupt if termios_dequeue_characters returns 0 AND there
> is no more data waiting for us in the uart register.
> Driver is attached.
> Regards,
> Tiemen Schut
> P.S. It appears that the same problems I (tried to) solve with this driver
> for sis/erc32 also hold for leon2/leon3. So if anyone is developing for
> leon2/leon3 and experiences console problems, I would strongly suggest you
> look at this driver and change the leon driver accordingly, for as far as the
> hardware is similar.
>>>> On 4/15/2010 at 16:11, in message <4BC73AC7020000520000FA9C at pluto.sron.nl>,
> > Hey all,
> > With help from Sebastian and Joell I've redone the erc32/sis console
> driver.
> > It now uses the shared console framework from rtems. First and foremost I
> > would like to say that it's still far from perfect, but it should be an
> > improvement to the old driver.
> > Note that my main goal was to get ppp working, as output from pppd stopped
> > after the first character. This should be solved with this driver, while
> > "regular" output is pretty much unchanged.
> > As I don't have an erc32 target I only tested with the sis version 2.7.5,
> so
> > there may be problems with a real target (or tsim, or another version of
> the
> > sis for that matter).
> > To get this to compile you'll have to change the
> > c/src/lib/libbsp/sparc/erc32/Makefile.am. Change console_SOURCES to be:
> > console_SOURCES = console/erc32_console.c ../../shared/console.c. To be
> sure
> > that you're compiling the right driver I would advice to remove/rename the
> > "old" console.c.
> > Happy testing!
> > Tiemen
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100423/a58a7f1c/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100423/a58a7f1c/attachment-0001.obj>
