Ada Toolchain for RTEMS 4.10/LEON3
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 28 21:17:20 UTC 2010
On 04/28/2010 04:06 PM, Peter Mendham wrote:
> Dear all,
> I have a requirement for Ada support on RTEMS 4.10 and, although I
> know that this is not currently supported, I thought I would give it a
> try. I have been following, roughly, the instructions on the wiki.
> My current build attempt is based on:
> binutils 2.201.1
> gmp 5.0.1
> mpc 0.8.1
> mpfr 2.4.2
> newlib 1.18.0
> gcc 4.5.0
> I build sparc-rtems binutils, a multilibbed native gcc with C and Ada
> support, a multilibbed sparc-rtems gcc with C and C++ support only,
> followed by a multilibbed sparc-rtems gcc with C, C++ and Ada
> support. I specify a sysroot during the cross-compile builds.
> Predictably, everything goes wrong for me during the final step. The
> build drops out with errors in gcc/ada/rts/socket.c. These seem to be
> related to missing types (especially struct servent). I'm guessing
> this should come from gsocket.h, and there are some interesting
> comments in that file about RTEMS support but I'm afraid that I don't
> understand a word of them.
> I previously tried a build with gcc 4.4.3 and got hung up on
> s-oscons.ads generation, again preventing socket code from compiling
> (but Ada code this time).
> Has anyone successfully built a multilibbed Ada toolchain for recent
> RTEMS versions? It looks some major issues have been resolved,
> especially since the wiki entry was written. Can anyone offer any advice?
Yes. :-D
I can't speak for the accuracy of the wiki at the moment but the
scripts in the gcc-testing CVS module can build it. The trick is
to build RTEMS with networking multilib'ed and install it
and the BSP you are interested in before building Ada.
http://www.rtems.org/pipermail/rtems-tooltestresults/2010-April/000337.html
There are two patches from the SVN head you need that were
too late for the branch.
2010-04-15 Joel Sherrill <joel.sherrill at oarcorp.com>
* g-socket.adb: A target can have multiple missing errno's. This
will result in multiple errno's being defined as -1. Because
of this
we can not use a case but must use a series of if's to avoid
a duplicate case error in GNAT.Sockets.Resolve_Error.
2010-04-13 Joel Sherrill <joel.sherrill at oarcorp.com>
* gsocket.h: Run-time can no longer be built without network
OS headers available. Changing RTEMS GNAT build procedure to
reflect this and letting run-time build use network .h files.
> Thanks in advance,
> Peter
> SciSys UK Limited. Registered in England and Wales No. 4373530.
> Registered Office: Methuen Park, Chippenham, Wiltshire SN14 0GB, UK.
> P Before printing, please think about the environment.
Joel Sherrill, Ph.D. Director of Research& Development
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20100428/adef8f47/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20100428/adef8f47/attachment-0001.ksh>
