FW: RTEMS Message Queue Behaviour
Aleix Conchillo Flaqué aconchillo at ice.csic.es
Fri Apr 9 11:51:38 UTC 2010
Then, I don't know. Probably Joel or others can help you, but it seems
to me an application problem.
About the message order, this can simply be a task priority issue,
unless you sent all messages from the same task, which I guess is what
you did to try this out.
On Fri, Apr 9, 2010 at 13:32, Jamie Bowman
<jamie.bowman at steepestascent.com> wrote:
> Aleix
> My apologies!
> Good call on the rtems_message_queue_receive parameters. However by chance,
> both RTEMS_WAIT and RTEMS_NO_TIMEOUT are defined as zero, so it wouldn't
> change the parameters actually sent to rtems_message_queue_receive.
> Kind regards
>        Jamie
