Mutlicast Failing without Adding route
John Wood jwood at scisol.com
Thu Aug 26 17:09:59 UTC 2010
Greetings all,
I am using rtems 4.9.2 on a custom PCB with 2 Ethernet interfaces.  If I don't add a route my multicast sends fail.  Is this the correct behavior?
I am not particularly familiar with multicast.  I have loopback enabled and when I receive the message it has the IP address of my interface as
Opposed to the broadcast address which seems incorrect to me but is it possibly correct.
I tried setting the interface using the IP_MULTICAST_IF but this does not appear to help.
Thanks for any insight,
John
URL: <http://lists.rtems.org/pipermail/users/attachments/20100826/bf7e4261/attachment.html>
