Mutlicast Failing without Adding route
Till Straumann strauman at slac.stanford.edu
Thu Aug 26 18:33:19 UTC 2010
This may give some insight:
https://www.rtems.org/bugzilla/show_bug.cgi?id=1381
HTH
-- Till
On 08/26/2010 12:09 PM, John Wood wrote:
> Greetings all,
> I am using rtems 4.9.2 on a custom PCB with 2 Ethernet interfaces.  If
> I don't add a route my multicast sends fail.  Is this the correct
> behavior?
> I am not particularly familiar with multicast.  I have loopback
> enabled and when I receive the message it has the IP address of my
> interface as
> Opposed to the broadcast address which seems incorrect to me but is it
> possibly correct.
> I tried setting the interface using the IP_MULTICAST_IF but this does
> not appear to help.
> Thanks for any insight,
> John
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100826/e6cff3b6/attachment-0001.html>
