Current status for running a ARM BSP on QEMU ?
Simon Clubley simon.clubley at googlemail.com
Fri Dec 31 14:39:20 UTC 2010
I have been looking at the possibility of running a ARM BSP under QEMU
and I have been reading through various online references.
I see there has been much talk of doing this, including some actual
plans to do so, but I haven't found any references to anyone actually
doing it as people (including myself :-)) seem to have been using
Skyeye for a emulator so far.
Has anyone actually got a ARM BSP running on QEMU ?
If you have, which BSP did you use ?
Also, given that QEMU is a full system emulator, did you create a disk
image (pc386/grub style) or did you emulate booting from flash ?
Thanks for any information/ideas,
Simon.
Simon Clubley
