clock_get_uptime
Gedare Bloom
gedare at gwu.edu
Fri Feb 19 22:35:25 UTC 2010
Hi,
I've written some code to try generating a synthetic load with a
(somewhat) predictable execution time. Based on a brief chat on IRC
with Joel, I decided to try using the clock_get_uptime routine. I see
that uptime is updated during the rtems_clock_tick routine, which is
typically called in the clock ISR provided by each individual BSP.
I implemented a load generating loop as part of an RTEMS app, using
the CVS head and pc386 BSP in QEMU. I observed some interesting
behavior when calling uptime in a tight loop. In particular, I get
some backwards time-travel.
Here is a snippet of the code:
rtems_clock_get_uptime(&start_ts);
while(FOREVER) {
rtems_clock_get_uptime(&stop_ts);
_Timespec_Subtract(&start_ts,&stop_ts,&diff_ts);
if (_Timespec_To_ticks(&diff_ts) >= Tick_Count[argument]) break;
here, start_ts, stop_ts, and diff_ts are all struct timespec, and
Tick_Count[argument] is a parametrized integer value. What is
happening is that the loop appears to be ending prematurely.
An example of the values of start_ts, stop_ts, and diff_ts are:
(gdb) p start_ts
$4 = {
tv_sec = 0,
tv_nsec = 200701252
(gdb) p stop_ts
$5 = {
tv_sec = 0,
tv_nsec = 200325952
(gdb) p diff_ts
$6 = {
tv_sec = -1,
tv_nsec = 999624700
I can see that stop_ts < start_ts, and that diff_ts reflects this
negative amount. I'm trying to figure out why this is happening. I
can trace stop_ts, and I am able to observe that it does in fact
increase, up to:
(gdb) p stop_ts
$27 = {
tv_sec = 0,
tv_nsec = 208797738
But then the next time I read stop_ts from clock_get_uptime, I get the
value 200325952. Does anyone know why this might be happening?
Thanks,
Gedare
