clock_get_uptime
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Feb 20 15:08:22 UTC 2010
On 02/19/2010 04:35 PM, Gedare Bloom wrote:
> Hi,
> I've written some code to try generating a synthetic load with a
> (somewhat) predictable execution time. Based on a brief chat on IRC
> with Joel, I decided to try using the clock_get_uptime routine. I see
> that uptime is updated during the rtems_clock_tick routine, which is
> typically called in the clock ISR provided by each individual BSP.
> I implemented a load generating loop as part of an RTEMS app, using
> the CVS head and pc386 BSP in QEMU. I observed some interesting
> behavior when calling uptime in a tight loop. In particular, I get
> some backwards time-travel.
> Here is a snippet of the code:
> rtems_clock_get_uptime(&start_ts);
> while(FOREVER) {
> rtems_clock_get_uptime(&stop_ts);
> _Timespec_Subtract(&start_ts,&stop_ts,&diff_ts);
> if (_Timespec_To_ticks(&diff_ts)>= Tick_Count[argument]) break;
> here, start_ts, stop_ts, and diff_ts are all struct timespec, and
> Tick_Count[argument] is a parametrized integer value. What is
> happening is that the loop appears to be ending prematurely.
> An example of the values of start_ts, stop_ts, and diff_ts are:
> (gdb) p start_ts
> $4 = {
> tv_sec = 0,
> tv_nsec = 200701252
> (gdb) p stop_ts
> $5 = {
> tv_sec = 0,
> tv_nsec = 200325952
> (gdb) p diff_ts
> $6 = {
> tv_sec = -1,
> tv_nsec = 999624700
> I can see that stop_ts< start_ts, and that diff_ts reflects this
> negative amount. I'm trying to figure out why this is happening. I
> can trace stop_ts, and I am able to observe that it does in fact
> increase, up to:
> (gdb) p stop_ts
> $27 = {
> tv_sec = 0,
> tv_nsec = 208797738
> But then the next time I read stop_ts from clock_get_uptime, I get the
> value 200325952. Does anyone know why this might be happening?
I have three guesses. The first is the unlikely case where
the tsc register from qemu isn't accurate. But I doubt
that.
The second is that the code in score/src/coretodgetuptime.c
or something it calls has a math mistake.
The third is that even though we haven't processed a
clock tick interrupt, the counter has "run to 0" or
whatever that means to the pc386 clock driver. A
clock tick interrupt is pending and the driver math
for nanoseconds since last tick isn't right in that case.
If it is right most of the time and fails sometimes, then
the 3rd case seems likely.
> Thanks,
> Gedare
> rtems-users mailing list
> rtems-users at rtems.org
