Interrupt Problems (again).
Gedare Bloom
gedare at gwu.edu
Fri Feb 12 17:55:43 UTC 2010
I haven't been using RTEMS that long, so I don't have much advice for
you, but I did have one thought to share.
Perhaps something strange is going on with a CPU dependent
implementation of _ISR_Is_in_progress. Try this:
> cd ${RTEMS}/cpukit/score/cpu/powerpc/rtems
> grep -r CPU_PROVIDES_ISR_IS_IN_PROGRESS *
If you get back something that says TRUE, that gives you something
else to look for. score relies on _ISR_Nest_level to determine whether
or not an interrupt is happening, but I suppose a mismatch between
_ISR_Nest_level and the result of rtems_interrupt_is_in_progress()
could be caused by a port that provides an alternate implementation of
AFAIK there aren't any ports that actually use this option in the
current release...
-Gedare
On Fri, Feb 12, 2010 at 11:47 AM, Nick Thomas <nick.thomas at pixsan.com> wrote:
> Hi,
> I am still having problems with interrupts.
> I reported a while ago that rtems_interrupt_is_in_progress() was returning
> the wrong value occasionally.
> Now, I see that I am getting an error 18 (RTEMS_CALLED_FROM_ISR) at a place
> in the code that definitely back-traces to a task!
> At the point of the crash I see that _ISR_Nest_level is zero, and
> _Thread_Dispatch_disable_level is 1 .
> I am using RTEMS 4.7.1 on a PowerPC 405, if that helps.
> I know that RTEMS 4.7.1 is quite old now, but I don't realistically have the
> ability to upgrade at this point in the project.
> Any help/comments/suggestions welcomed.
> Regards
> Nick
> Nick Thomas
> Email: nick.thomas at pixsan.com
> rtems-users mailing list
> rtems-users at rtems.org
