Exception Handling
Till Straumann
strauman at slac.stanford.edu
Mon Feb 15 16:27:27 UTC 2010
Cassia Yuri wrote:
> Dear all,
> Is it possible to modify the context for which the processor returns
> after an exception? I need the faulty task (task that caused the
> exception) to be suspended while another task (specific for this
> situation) gains control and then delete (or not) the faulty one.
> I can't see how to do that now; by not deleting the faulty task as a
> response to the exception (within an interrupt request handler or
> within _defaultExcHandler in cpu.c) I get stucked in a loop executing
> the instruction causing the exception and the exception handling.
You can e.g., from the exception handler
post a pointer to the exception context or the TID to the
handling task with rtems_message_queue_send().
After that you can (still from the exception handler) execute
rtems_task_suspend(RTEMS_SELF).
The exception handling task can inspect the exception context,
try to fix it and if that succeeds issue rtems_task_resume(exc_context->tid)
(assuming the exception context contains the TID of the interrupted
task).
HTH
-- Till
> Any help/correction is very welcome,
> best regards,
> Cássia
> rtems-users mailing list
> rtems-users at rtems.org
