Need help to explain the test result
Leon Pollak leonp at plris.com
Sun Jan 10 15:17:02 UTC 2010
Hello, all.
I am trying to do the task switch logger.
For this I installed the user extension and the function "TASK SWITCH
Extension", which logs (into cyclic buffer) the current_task->Object.name.
Everything seems to work, but I have 2 questions:
1. Sometimes I see the name 0x10e150 to appear. Under debugger, I see this
name when an external interrupt occurs and task switch is called from the ISR
handler. Strange, as I thought that IRQ has no "task" context. OK, but what is
this name? I did:
(gdb) p/x current_task->Object
$59 = {Node = {next = 0x54f410, previous = 0x54f40c}, id = 0x9010001, name =
0x10e150}
2. For now, I designated the above as "*IRQ" name and continued. Then, I
received something that I can not understand:
*IRQ    MRT2    V2HD    FCr1    FCr1    V2HD    FCr1    FCr1    V2HD    FCr1
V2HD    FCr1
How can it be that FCr1 is repeated? There was a context switch to itself!?
Many thanks for the help.
Leon
