rtems_interrupt_is_in_progress() not working.
Sebastian Huber
Mon Jan 11 16:00:46 UTC 2010
Nick Thomas wrote:
>> -----Original Message-----
>> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Sent: 11 January 2010 08:11
>> To: Nick Thomas
>> Cc: rtems-users at rtems.com
>> Subject: Re: rtems_interrupt_is_in_progress() not working.
>> Nick Thomas wrote:
>>> But, I suspect that my problem is caused by
>>> rtems_interrupt_is_in_progress() being called from within a genuine
>>> hardware interrupt - not a timer interrupt.
>>> Does that make a difference?
>> It should not make a difference. Which RTEMS version and BSP do you
>> use? How do you install the interrupt handler?
> I am using the PowerPC 405 architecture, with rtems version 4.7.1 .
Sorry, this version existed before I started to use RTEMS. The PowerPC
exception handling changed a lot in the mean time.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
