rtems_interrupt_is_in_progress() not working.
Nick Thomas nick.thomas at pixsan.com
Mon Jan 11 15:40:11 UTC 2010
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: 11 January 2010 08:11
> To: Nick Thomas
> Cc: rtems-users at rtems.com
> Subject: Re: rtems_interrupt_is_in_progress() not working.
> Nick Thomas wrote:
> > But, I suspect that my problem is caused by
> > rtems_interrupt_is_in_progress() being called from within a genuine
> > hardware interrupt - not a timer interrupt.
> > Does that make a difference?
> It should not make a difference.  Which RTEMS version and BSP do you
> use?  How do you install the interrupt handler?
I am using the PowerPC 405 architecture, with rtems version 4.7.1 .
Interrupts are installed using this function:
-- SNIP --
if (ictrl_set_vector((rtems_isr_entry)int_handler, mappedLevel, &old_handle)
== RTEMS_SUCCESSFUL)
	return 0;
else
	return 1;
-- SNIP --
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
