rtems_interrupt_is_in_progress() not working.
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Mon Jan 11 15:59:14 UTC 2010
Nick,
without going into the details concerning your current problem: 4.7.1 is
rather old, we are currently aproaching 4.10. Among others,  the
exception handling code for PPC has seen a major rework.
So you should strongly consider upgrading to the current snapshot or
release.
Regarding your problem: you should try to inspect the _ISR_nest_level
when you hit your error. what is the value of it when you hit the error?
wkr,
Thomas.
Nick Thomas wrote:
>> -----Original Message-----
>> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Sent: 11 January 2010 08:11
>> To: Nick Thomas
>> Cc: rtems-users at rtems.com
>> Subject: Re: rtems_interrupt_is_in_progress() not working.
>> Nick Thomas wrote:
>>> But, I suspect that my problem is caused by
>>> rtems_interrupt_is_in_progress() being called from within a genuine
>>> hardware interrupt - not a timer interrupt.
>>> Does that make a difference?
>> It should not make a difference.  Which RTEMS version and BSP do you
>> use?  How do you install the interrupt handler?
> I am using the PowerPC 405 architecture, with rtems version 4.7.1 .
> Interrupts are installed using this function:
> -- SNIP --
> if (ictrl_set_vector((rtems_isr_entry)int_handler, mappedLevel, &old_handle)
> == RTEMS_SUCCESSFUL)
> 	return 0;
> else
> 	return 1;
> -- SNIP --
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone   : +49 89 18 90 80 79-6
>> Fax     : +49 89 18 90 80 79-9
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> rtems-users mailing list
> rtems-users at rtems.org
Thomas Doerfler        Obere Lagerstrasse 30
D-82178 Puchheim       Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
PGP:   Public key available on request.
