how to make work my networkdriver for MULTICAST and TIMESTAMP with rtems
Till Straumann strauman at slac.stanford.edu
Wed Jan 13 14:43:24 UTC 2010
Diego Sanz wrote:
> Hello and happy new year for all.
> I have RTEMS working for the mcf5234, a coldfire of Motorola. Once I
> have the network working, now I need to implement in the driver the
> changes to be able to send and recieve multicast packets. Addition, I
> have to make to the sockets be able to take the time stamp.
> The first I thought, was to look in the RTEMS source, looking where
> the code for the socket make the call to the function IOCTL that calls
> to the network.c driver ioctl function, becose if I know how the
> system make the call, then I will know how to make the appropriate
> changes.
E.g., this driver (as of rtems-4.9.3) does implement SIOCADDMULTI /
SIOCDELMULTI:
c/src/lib/libbsp/powerpc/mvme3100/network/tsec.c
If you do implement these for your driver then don't forget
to add IFF_MULTICAST to if_flags in the 'attach' function.
HTH
-- Till
> I am taking too much time, because search through to the all source
> lloking for structures... where the functions are attached...
> could tell me some one something that could help me? some example...
> although the microcontroller will be different.
> A lot of thanks
> best regards
> Diego Sanz
> rtems-users mailing list
> rtems-users at rtems.org
