Problem installing tools with Yum on RHEL 5.2
Robert S. Grimes
rsg at alum.mit.edu
Wed Jan 13 15:52:07 UTC 2010
Thanks Ralf and Daron,
I was wondering if that (root) was the issue. I'm
forwarding this to my sys admin for his help.
Cheers,
-Bob
---- Original message ----
Date: Wed, 13 Jan 2010 16:25:45 +0100
Subject: Re: Problem installing tools with Yum on
RHEL 5.2
To: rsg at alum.mit.edu
Cc: rtems-users at rtems.org
>On 01/13/2010 03:40 PM, Robert S. Grimes wrote:
>> Hi,
>> Finally bit the bullet, got a RedHat system,
and am
>> trying to install the tools using Yum, which is
new
>> to me. Here is the results:
>> rsg at ws:~/tmp $ ls
>> rtems-4.9-release-0.21-1.el5.noarch.rpm
>> rtems-4.9-yum-conf-0.21-1.el5.noarch.rpm
>> rsg at ws:~/tmp $ rpm -ivh
>> warning:
rtems-4.9-yum-conf-0.21-1.el5.noarch.rpm:
>> Header V4 DSA signature: NOKEY, key ID 69ce4a83
>> error: Failed dependencies:
>> rtems-4.9-release = 0.21-1.el5 is needed by
>> Looks like I'm missing something,
>Yep, you are facing 2 to 3 issues at once.
>0. You need to be root to run yum/rpm
>1. You don't have having the rtems key installed
>2. You are installing out of sequence.
>There are several ways to "fix" this.
>The easiest way is to use yum (All one line):
># yum --nogpg localinstall \
>rtems-4.9-release-0.21-1.el5.noarch.rpm \
>This will install the rtems keys (contained in
*-release) and the
>rtems-4.9 repository's yum configuration.
>Afterwards use yum, rpm, PackageKit, yumex or
else like you would use
>any other repository.
>> though it seems
>> I'm following the wiki instructions...
>Well, due to a recent change, they are outdated.
>Ralf
Robert S. Grimes
RSG Associates
Embedded Systems and Software Development
for Military, Aerospace, Industry - and beyond!
617.697.8579
www.rsgassoc.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20100113/227ddf3c/attachment.html>
