Problem when suspending a task.
Eric Norum wenorum at lbl.gov
Wed Jan 6 14:50:53 UTC 2010
There are lots of places in the I/O code where a mutex is held.   Suspending or destroying another task while it's holding a mutex is a sure way to lock up the system.   You should rethink your design and determine some way to avoid such operations except from within the task itself.
Eric Norum
wenorum at lbl.gov
On Jan 6, 2010, at 5:55 AM, Nick Thomas wrote:
> Hi,
> Not much to go on with this, but I am suffering from a weird problem shortly
> after a task is suspended using rtems_task_suspend.
> The problem is that lots of other tasks appear hung too, not just the one I
> wanted to suspend.
> This includes the rtems monitor task, so getting info out of the unit is
> very difficult.
> I don't really know where to start looking for the cause of this issue.
> Bizarrely, the task which is being suspended has a lot of printf statements.
> If I remove these printf statements then the problem doesn't happen and the
> unit continues to function normally.
> Is there a problem when suspending a task when it is in the middle of a
> printf statement?
> Regards
> Nick
> Nick Thomas
> Email: nick.thomas at pixsan.com
> rtems-users mailing list
> rtems-users at rtems.org
Eric Norum
wenorum at lbl.gov
