RTEMS Shell
rtwas
rtwas at comcast.net
Wed Jan 13 22:16:25 UTC 2010
Hello,
Joel Sherrill wrote:
> On 01/13/2010 03:27 PM, rtwas wrote:
> > Hello,
> > I'm wanting to add *multiple* user commands to Rtems Shell. The
> > examples show how to add *one* command but do not show how to add
> > *n* commands.
> > To the point, to add a single command (after defining the function)
> > one does:
> > "#define CONFIGURE_SHELL_USER_COMMANDS&Shell_USERCMD_Command"
> > where "Shell_USERCMD_Command" is a structure describing the
> > function. The only way I can see to add multiple commands is to
> > define separate structures and add multiple pointers to the
> > "CONFIGURE_SHELL_USER_COMMANDS" macro ie.,
> > "#define CONFIGURE_SHELL_USER_COMMANDS&Shell_USERCMD0_Command
> > &Shell_USERCMD1_Command.."
> > or some how make use of the "next" entry in the
> > "rtems_shell_cmd_t" struct to create a linked list of commands. The
> > docs are not clear here.
> From a user application I helped with that added a set of custom
> commands for a multi-IO PC-104 board.
> #define CONFIGURE_PCMMIO_COMMANDS \ &Shell_PCMMIO_DIN_Command, \
> &Shell_PCMMIO_DOUT_Command, \ &Shell_PCMMIO_ADC_Command, \
> &Shell_PCMMIO_DAC_Command, \ &Shell_PCMMIO_IRQ_Command, \
> &Shell_PCMMIO_Benchmark_Command
> #define CONFIGURE_SHELL_USER_COMMANDS \ CONFIGURE_PCMMIO_COMMANDS
Interesting. I'm guessing they have to be parsing
"CONFIGURE_SHELL_USER_COMMANDS" to
get the pointers out.
I hadn't expected such a speedy response so I thought I'd experiment:
#include <rtems/shell.h>
int
main_vmemw32(int argc, char **argv)
printf("vmemw32(): ... \n");
printf("\n");
return(0);
int
main_vmemr32(int argc, char **argv)
printf("vmemr32(): ... \n");
printf("\n");
return(0);
rtems_shell_cmd_t Shell_VMEMW32_Command =
"vmemw32", /* name */
"usercmd n1 [n2 [n3...]]", /* usage */
"user", /* topic */
main_vmemw32, /* command */
NULL, /* alias */
NULL /* next */
rtems_shell_cmd_t Shell_VMEMR32_Command =
"vmemr32", /* name */
"user", /* topic */
main_vmemr32, /* command */
NULL, /* alias */
&Shell_VMEMW32_Command, /* next */
#define CONFIGURE_SHELL_USER_COMMANDS &Shell_VMEMR32_Command
#define CONFIGURE_SHELL_COMMANDS_INIT
#define CONFIGURE_SHELL_COMMANDS_ALL
#define CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING
#include <rtems/shellconfig.h>
..and I got lucky, it worked. In this case I *assumed the "next" field was
to create a linked list.
> I think you should be able to have a "shell_config.c" and do it
> there. It is based on confdefs.h and I know you can do that with
> confdefs.h.
> --joel
Yes, this is all in its own "C" file.
Shows up in the "help" menu too. :)
Thanks Joel.
Robert W.
