rtems toolchain for arm11
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Jan 23 15:59:29 UTC 2010
On 01/22/2010 07:34 PM, Syed Khader wrote:
> Hi,
> I am trying to port rtems-4.9 onto a new arm11(arm1176) based board.
> I would like to know if the toolchain rtems-4.9-gcc(version 4.3.2)
> which I have installed from rtems ftp site, would work for arm11.
> Going by the rtem-4.9.3 sources, it seems there is no arm11 based bsp yet.
Start with the CVS head. There has been a lot of arm work
and some remains before the 4.10 branch is made. That is
the major remaining issue.
There is a gdbarmsim BSP which can be aliased to any CPU
combination to check out context switch and basic issues
on the arm simulator in gdb. No interrupts.
If anything has to be worked on in RTEMS, it will be the
interrupts. Somewhere along the arm cpu line, they changed
some details which I don't recall on a Saturday morning.
But the BSP is likely all new.
--joel
> TIA
> -syed
> rtems-users mailing list
> rtems-users at rtems.org
