rtems toolchain for arm11
Mon Jan 25 07:58:41 UTC 2010
Hi,
the ARM1176 should work with the new (coming soon?) tool chain for RTEMS 4.10
(the current and previous tool chains have a problem on little-endian ARM with
floating point operations).  An ARM core with Thumb2 instruction set may
require a tool chain update, since we do not have a Thumb2 multi lib currently.
You should use the CVS head for development of your new BSP.
CU
On 2010-01-23 02:34, Syed Khader wrote:
> Hi,
>   I am trying to port rtems-4.9 onto a new arm11(arm1176) based board.
>  I would like to know if the toolchain rtems-4.9-gcc(version 4.3.2)
> which I have installed from rtems ftp site, would work for arm11.
>    Going by the rtem-4.9.3 sources, it seems there is no arm11 based bsp yet.
> TIA
> -syed
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
