where are patch files for binutils 2.18 to build RTEMS 4.9.3?
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jan 28 22:17:48 UTC 2010
On 01/28/2010 03:53 PM, mike wrote:
> Hi all,
> I'm trying to gather all the files to build RTEMS 4.9.3.
> The RTEMS online page referred to:
> RTEMS Specific Tool Patches and Scripts
> FTP Site: ftp.rtems.com
> Directory: /pub/rtems/SOURCES/4.9
> File: binutils-2.18-rtems4.9-20080211.diff
> File: newlib-1.16.0-rtems4.9-20080827.diff
> File: gcc-4.3.2-rtems4.9-20080917.diff
> URL: ftp://ftp.rtems.com/pub/rtems/SOURCES/4.9
> - I couldn't find 'binutils-2.18-rtems4.9-20080211.diff'? (and I
> couldn't find any patch for binutils 2.18?)
Always look in the contrib/crossrpms/patches. The newest patches
for the branch you are looking at are always there.
-bash-4.0$ cd contrib/crossrpms/patches/
-bash-4.0$ ls
binutils-2.17.50-cygwin-20060817-1.diff gdb-6.8-rtems4.9-20090312.diff
binutils-2.18-rtems4.9-20080211.diff gdb-6.8-rtems4.9-20090721.diff
CVS gdb-6.8-rtems4.9-20090923.diff
gcc-ada-4.2.0-rtems4.8-20070705.diff gdb-6.8-rtems4.9-20091111.diff
gcc-core-4.3.2-rtems4.9-20081214.diff
newlib-1.16.0-rtems4.9-20080430.diff
gcc-core-4.3.2-rtems4.9-20090825.diff
gdb-6.5-bfinrtems-20090122.diff
newlib-1.16.0-rtems4.9-20081203.diff
gdb-6.8-rtems4.9-20080429.diff
newlib-1.16.0-rtems4.9-20090207.diff
gdb-6.8-rtems4.9-20080917.diff
newlib-1.16.0-rtems4.9-20090324.diff
> - I assumed I can use 'newlib-1.16.0-rtems4.9-20090324.diff' which is newer than the one documented?
> - same for gcc: use 'gcc-core-4.3.2-rtems4.9-20090825.diff' which is newer? Then why is there a different
> 'gcc-core-4.3.2-rtems4.9-20081214.diff' in there?
History. And it helps if you need to remove the old patch before
installing the new one.
If starting from a fresh untar, use the newest.
> Thanks for any help.
> -mike-
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
