where are patch files for binutils 2.18 to build RTEMS 4.9.3?
mike
antispam21 at verizon.net
Thu Jan 28 22:26:54 UTC 2010
Thanks Joel,
Where is this 'contrib/crossrpms/patches'?
-mike-
Joel Sherrill wrote:
> On 01/28/2010 03:53 PM, mike wrote:
>> Hi all,
>> I'm trying to gather all the files to build RTEMS 4.9.3.
>> The RTEMS online page referred to:
>> RTEMS Specific Tool Patches and Scripts
>> FTP Site: ftp.rtems.com
>> Directory: /pub/rtems/SOURCES/4.9
>> File: binutils-2.18-rtems4.9-20080211.diff
>> File: newlib-1.16.0-rtems4.9-20080827.diff
>> File: gcc-4.3.2-rtems4.9-20080917.diff
>> URL: ftp://ftp.rtems.com/pub/rtems/SOURCES/4.9
>> - I couldn't find 'binutils-2.18-rtems4.9-20080211.diff'? (and I
>> couldn't find any patch for binutils 2.18?)
> Always look in the contrib/crossrpms/patches. The newest patches
> for the branch you are looking at are always there.
> -bash-4.0$ cd contrib/crossrpms/patches/
> -bash-4.0$ ls
> binutils-2.17.50-cygwin-20060817-1.diff gdb-6.8-rtems4.9-20090312.diff
> binutils-2.18-rtems4.9-20080211.diff gdb-6.8-rtems4.9-20090721.diff
> CVS gdb-6.8-rtems4.9-20090923.diff
> gcc-ada-4.2.0-rtems4.8-20070705.diff gdb-6.8-rtems4.9-20091111.diff
> gcc-core-4.3.2-rtems4.9-20081214.diff
> newlib-1.16.0-rtems4.9-20080430.diff
> gcc-core-4.3.2-rtems4.9-20090825.diff
> gdb-6.5-bfinrtems-20090122.diff
> newlib-1.16.0-rtems4.9-20081203.diff
> gdb-6.8-rtems4.9-20080429.diff
> newlib-1.16.0-rtems4.9-20090207.diff
> gdb-6.8-rtems4.9-20080917.diff
> newlib-1.16.0-rtems4.9-20090324.diff
>> - I assumed I can use 'newlib-1.16.0-rtems4.9-20090324.diff' which is
>> newer than the one documented?
>> - same for gcc: use 'gcc-core-4.3.2-rtems4.9-20090825.diff' which is
>> newer? Then why is there a different
>> 'gcc-core-4.3.2-rtems4.9-20081214.diff' in there?
> History. And it helps if you need to remove the old patch before
> installing the new one.
> If starting from a fresh untar, use the newest.
>> Thanks for any help.
>> -mike-
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
