where are patch files for binutils 2.18 to build RTEMS 4.9.3?
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jan 28 23:01:08 UTC 2010
On 01/28/2010 04:26 PM, mike wrote:
> Thanks Joel,
> Where is this 'contrib/crossrpms/patches'?
Top of the source tree. If not in the tarball (I don't recall
if it is filtered out), then check out the 4.9 branch from
CVS. It is definitely there.
--joel
> -mike-
> Joel Sherrill wrote:
>> On 01/28/2010 03:53 PM, mike wrote:
>>> Hi all,
>>> I'm trying to gather all the files to build RTEMS 4.9.3.
>>> The RTEMS online page referred to:
>>> RTEMS Specific Tool Patches and Scripts
>>> FTP Site: ftp.rtems.com
>>> Directory: /pub/rtems/SOURCES/4.9
>>> File: binutils-2.18-rtems4.9-20080211.diff
>>> File: newlib-1.16.0-rtems4.9-20080827.diff
>>> File: gcc-4.3.2-rtems4.9-20080917.diff
>>> URL: ftp://ftp.rtems.com/pub/rtems/SOURCES/4.9
>>> - I couldn't find 'binutils-2.18-rtems4.9-20080211.diff'? (and I
>>> couldn't find any patch for binutils 2.18?)
>> Always look in the contrib/crossrpms/patches. The newest patches
>> for the branch you are looking at are always there.
>> -bash-4.0$ cd contrib/crossrpms/patches/
>> -bash-4.0$ ls
>> binutils-2.17.50-cygwin-20060817-1.diff gdb-6.8-rtems4.9-20090312.diff
>> binutils-2.18-rtems4.9-20080211.diff gdb-6.8-rtems4.9-20090721.diff
>> CVS gdb-6.8-rtems4.9-20090923.diff
>> gcc-ada-4.2.0-rtems4.8-20070705.diff gdb-6.8-rtems4.9-20091111.diff
>> gcc-core-4.3.2-rtems4.9-20081214.diff
>> newlib-1.16.0-rtems4.9-20080430.diff
>> gcc-core-4.3.2-rtems4.9-20090825.diff
>> gdb-6.5-bfinrtems-20090122.diff
>> newlib-1.16.0-rtems4.9-20081203.diff
>> gdb-6.8-rtems4.9-20080429.diff
>> newlib-1.16.0-rtems4.9-20090207.diff
>> gdb-6.8-rtems4.9-20080917.diff
>> newlib-1.16.0-rtems4.9-20090324.diff
>>> - I assumed I can use 'newlib-1.16.0-rtems4.9-20090324.diff' which is
>>> newer than the one documented?
>>> - same for gcc: use 'gcc-core-4.3.2-rtems4.9-20090825.diff' which is
>>> newer? Then why is there a different
>>> 'gcc-core-4.3.2-rtems4.9-20081214.diff' in there?
>> History. And it helps if you need to remove the old patch before
>> installing the new one.
>> If starting from a fresh untar, use the newest.
>>> Thanks for any help.
>>> -mike-
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D. Director of Research& Development
