rtems_interrupt_is_in_progress() not working.
Nick Thomas
nick.thomas at pixsan.com
Fri Jan 29 17:15:21 UTC 2010
> -----Original Message-----
> From: Thomas Doerfler [mailto:Thomas.Doerfler at embedded-brains.de]
> Sent: 11 January 2010 15:59
> To: Nick Thomas
> Cc: 'Sebastian Huber'; rtems-users at rtems.com
> Subject: Re: rtems_interrupt_is_in_progress() not working.
> Nick,
> without going into the details concerning your current problem: 4.7.1
> is rather old, we are currently aproaching 4.10. Among others, the
> exception handling code for PPC has seen a major rework.
> So you should strongly consider upgrading to the current snapshot or
> release.
> Regarding your problem: you should try to inspect the _ISR_nest_level
> when you hit your error. what is the value of it when you hit the
> error?
Dear Thomas,
I know this thread is a couple of weeks old, but I am still experiencing
this problem of rtems_interrupt_is_in_progress() not working properly.
I checked the value of _ISR_nest_level when the problem happens, and it is
zero.
In the meantime, I am trying to upgrade my build to use something newer than
version 4.7.1, but it won't be ready for a while.
So, does the _ISR_nest_level being equal to zero highlight where the problem
is?
Regards
Nick
> wkr,
> Thomas.
> >> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> >> Sent: 11 January 2010 08:11
> >> To: Nick Thomas
> >> Cc: rtems-users at rtems.com
> >> Nick Thomas wrote:
> >>> But, I suspect that my problem is caused by
> >>> rtems_interrupt_is_in_progress() being called from within a genuine
> >>> hardware interrupt - not a timer interrupt.
> >>> Does that make a difference?
> >> It should not make a difference. Which RTEMS version and BSP do you
> >> use? How do you install the interrupt handler?
> > I am using the PowerPC 405 architecture, with rtems version 4.7.1 .
> > Interrupts are installed using this function:
> > -- SNIP --
> > if (ictrl_set_vector((rtems_isr_entry)int_handler, mappedLevel,
> > &old_handle) == RTEMS_SUCCESSFUL) {
> > return 0;
> > else
> > return 1;
> > -- SNIP --
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> >> Phone : +49 89 18 90 80 79-6
> >> Fax : +49 89 18 90 80 79-9
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> EHUG.
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Thomas Doerfler Obere Lagerstrasse 30
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at embedded-brains.de
> Phone: +49-89-18908079-2
> Fax: +49-89-18908079-9
> PGP: Public key available on request.
