Access my local files using RTEMS
Vinu Rajashekhar vinutheraj at gmail.com
Thu Jul 15 11:21:42 UTC 2010
On Thu, Jul 15, 2010 at 12:42 PM, Till Straumann <strauman at slac.stanford.edu
> wrote:
> On 07/15/2010 08:55 AM, Chris Johns wrote:
>> On 12/07/10 1:48 AM, Vinu Rajashekhar wrote:
>>> I have a follow-up question based on this.
>>> I could access my local files using pc386
>>> script and qemu -hda fat: option.
>>> Similarly, does all the other targets also support
>>> something like this, if the simulator is not qemu ?
>> Sorry to butt in on your thread :) :)
>> Yes qemu provides access via the FAT emulation method. This method has a
>> limited number of files that can be seen. I am not sure what the limit is
>> but a large tree of files results in files not appearing with no errors or
>> warnings.
>> On real hardware with working networking configurations I use the NFS file
>> system.
> Obviously, on qemu you can also use NFS or TFTPFS.
I wanted to use this for running a testsuite, because some of the
tests were accessing data files. So DrJoel advised me that it would
be better to use the technique used in network-demos - tar the filesystem,
then load it in IMFS using rtems_tarfs_load/Untar_FromMemory.
So finally I went with that.
- Till
>> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20100715/1b38bce8/attachment-0001.html>
