telnetd server application
Yann Sionneau
yann at minet.net
Sun Jul 25 10:42:50 UTC 2010
Thanks Joel & Till it helped a lot, telnetd starts well, the problem
comes from my ethernet driver now :)
Le 24/07/2010 15:54, Joel Sherrill a écrit :
> On 07/24/2010 02:08 AM, Till Straumann wrote:
>> Most likely a configuration issue. Did you see the line
>> 'registering the PTY driver FAILED'? That probably means
>> you hit the driver limit.
>> Try
>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>> or some other reasonable number.
> How about CONFIGURE_MAXIMUM_PTYS?
> Yann.. did you look at the network-demos/telnetd? network-demos
> is a separate CVS module.
> --joel
>> HTH
>> - Till
>> On 07/23/2010 11:23 PM, Yann Sionneau wrote:
>>> ok ... just forgot the attachement !
>>> Le 23/07/2010 23:21, Yann Sionneau a écrit :
>>>> Hi,
>>>> I am trying to use the telnetd included in RTEMS source tree to
>>>> start a
>>>> shell in order to do a nice sample application for the Ethernet driver
>>>> of milkymist bsp.
>>>> Is there some documentation about how to use it ?
>>>> I tried what i thought was correct, according to what i've read in the
>>>> telnetd source code.
>>>> I've put the code i am using as attachment.
>>>> I get this error running the application :
>>>> *** MILKYMIST NETWORKING TEST by Yann Sionneau ***
>>>> == Initializing Network ==
>>>> == Starting telnetd ==
>>>> WARNING: registering the PTY driver FAILED
>>>> telnetd cannot initialize PTY driver
>>>> If you have some advice i would really appreciate :)
>>>> Cheers,
