[Milkymist-devel] telnetd server application
Yann Sionneau yann at minet.net
Sun Jul 25 16:09:11 UTC 2010
Hi again !
The ethernet driver was totally wrong, i corrected it now it seems ok
I have another problem with telnetd now :
syslog: telnetd: accepted connection from 192.168.101.254 on /dev/pty0
unable to open stdio: I/O error
syslog: telnetd: releasing connection from 192.168.101.254 on /dev/pty0
do you know how to correct this ?
Sorry for flooding the list with my problems :)
Le 25/07/2010 12:42, Yann Sionneau a écrit :
> Thanks Joel & Till it helped a lot, telnetd starts well, the problem
> comes from my ethernet driver now :)
> Le 24/07/2010 15:54, Joel Sherrill a écrit :
>> On 07/24/2010 02:08 AM, Till Straumann wrote:
>>> Most likely a configuration issue. Did you see the line
>>> 'registering the PTY driver FAILED'? That probably means
>>> you hit the driver limit.
>>> Try
>>> #define CONFIGURE_MAXIMUM_DRIVERS 10
>>> or some other reasonable number.
>> How about CONFIGURE_MAXIMUM_PTYS?
>> Yann.. did you look at the network-demos/telnetd?   network-demos
>> is a separate CVS module.
>> --joel
>>> HTH
>>> - Till
>>> On 07/23/2010 11:23 PM, Yann Sionneau wrote:
>>>> ok ... just forgot the attachement !
>>>> Le 23/07/2010 23:21, Yann Sionneau a écrit :
>>>>> Hi,
>>>>> I am trying to use the telnetd included in RTEMS source tree to
>>>>> start a
>>>>> shell in order to do a nice sample application for the Ethernet driver
>>>>> of milkymist bsp.
>>>>> Is there some documentation about how to use it ?
>>>>> I tried what i thought was correct, according to what i've read in the
>>>>> telnetd source code.
>>>>> I've put the code i am using as attachment.
>>>>> I get this error running the application :
>>>>> *** MILKYMIST NETWORKING TEST by Yann Sionneau ***
>>>>> == Initializing Network ==
>>>>> == Starting telnetd ==
>>>>> WARNING: registering the PTY driver FAILED
>>>>> telnetd cannot initialize PTY driver
>>>>> If you have some advice i would really appreciate :)
>>>>> Cheers,
> http://lists.milkymist.org/listinfo.cgi/devel-milkymist.org
> IRC: #milkymist at Freenode
> Webchat: www.milkymist.org/irc.html
> Wiki: www.milkymist.org/wiki
