GeSys on a mvme167?
Daron Chabot daron.chabot at gmail.com
Wed Jul 28 15:54:13 UTC 2010
On Wed, Jul 28, 2010 at 11:42 AM, Jan C. Bernauer <bernauer at mit.edu> wrote:
>  On 28.07.10 11:29, Jan C. Bernauer wrote:
>>  On 28.07.10 10:42, Joel Sherrill wrote:
>>> On 07/28/2010 09:32 AM, Jan C. Bernauer wrote:
>>>>  Please ignore that, it works now. My build system was confused.
>>>> Configure, make clean and make helped.
>>>>  Does this mean that cexp works on mvme167?
>> Yes! I get a shell. Some bugs remain, for example lkup.help(1) dies with a
>> Null pointer dereference.
>> Debugging that right now.
> It seems cexpSystemModule has a 0 in segs. Any hints?
Are you using Till's GeSys (Generic System) code too ?
see: http://www.slac.stanford.edu/~strauman/rtems/software.html
Cexp needs to have the system's symbol table (the system 'module')
available. This can either be loaded from TFTP or NFS, or built into the
boot image itself.
> Best regards,
> Jan
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100728/0d447d4d/attachment-0001.html>
