GeSys on a mvme167?
Jan C. Bernauer bernauer at mit.edu
Wed Jul 28 16:05:22 UTC 2010
  On 28.07.10 11:54, Daron Chabot wrote:
> On Wed, Jul 28, 2010 at 11:42 AM, Jan C. Bernauer <bernauer at mit.edu
> <mailto:bernauer at mit.edu>> wrote:
>      On 28.07.10 11:29, Jan C. Bernauer wrote:
>          On 28.07.10 10:42, Joel Sherrill wrote:
>             On 07/28/2010 09:32 AM, Jan C. Bernauer wrote:
>                  Please ignore that, it works now. My build system was
>                 confused.
>                 Configure, make clean and make helped.
>             Does this mean that cexp works on mvme167?
>         Yes! I get a shell. Some bugs remain, for example lkup.help(1)
>         dies with a Null pointer dereference.
>         Debugging that right now.
>     It seems cexpSystemModule has a 0 in segs. Any hints?
> Are you using Till's GeSys (Generic System) code too ?
> see: http://www.slac.stanford.edu/~strauman/rtems/software.html
> <http://www.slac.stanford.edu/%7Estrauman/rtems/software.html>
> Cexp needs to have the system's symbol table (the system 'module')
> available. This can either be loaded from TFTP or NFS, or built into
> the boot image itself.
Yes. It should be builtin, at least lkup("string") finds something.
lkup.help() works too, but lkup.help(1) dies.
Best regards,
Jan
