Thread-safeness of API functions
Joris van Rantwijk
jorisvr at sron.nl
Fri Jul 30 16:33:31 UTC 2010
On Friday, July 30, 2010 17:41:34 Joel Sherrill wrote:
> For most of the reentrancy support, newlib uses a REENT
> structure which is context switched by RTEMS on a per-thread
> basis. This covers most methods but not some FILE * AFAIK.
I could not figure out the REENT mechanism. If REENT is switched per
task, is it not a problem when an ASR handler calls library functions
concurrently with the main code?
> At this point, there is a PR to add this support and
> it has patches. If you are interested in this, it would be
> a help to review and help shepherd the patches through
> the newlib and RTEMS projects.
Can you point me at the project? I'm not sure there is anything I can
do, but I will look for something.
In any case thanks for your answers. Looks like I'm going to add a
printf_mutex to my application.
> Picky stuff under the hood. :)
But this should not be under the hood. This is part of the definition of
the API. There should be a "thread-safe/unsafe" dashboard light :)
Joris.
