still can't boot mvme2100
Heinz Junkes
junkes at fhi-berlin.mpg.de
Tue Jun 8 12:49:29 UTC 2010
Hi,
i have now made a fresh installtion of rtems-tools 4.10 from source for powerpc on debian lenny 5.0.4.
From the cvs i have loaded the rtems-4.9.4.
I could the hello_world test file. But still run into "Illegal Instruction" when i start hello.ralf
as i mentioned in my last mail:
Network Boot File load in progress... To abort hit<BREAK>
Bytes Received =&2524435, Bytes Loaded =&2524435
Bytes/Second =&841478, Elapsed Time =3 Second(s)
Exception: Program (Illegal Instruction)
SRR0 =001F0000 SRR1 =00083040 Vector-Offset =00700
The cpu board i use have 64 Mbyte of memory installed. Have i to modify mvme2100.cfg, linkcmds ?
Will the mvme3100 - board run with RTEMS? I would buy such kind of boards if i can not get the mvme2100
to run in the next two month ...
Regards,
Heinz
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20100608/8d0460f0/attachment.bin>
