still can't boot mvme2100
Till Straumann
strauman at slac.stanford.edu
Tue Jun 8 18:18:56 UTC 2010
Just to make sure - you do have the ENV parameter
Network PReP-Boot Mode Enable [Y/N]
set to 'Y', right?
-- Till
On 06/08/2010 07:49 AM, Heinz Junkes wrote:'
> Hi,
> i have now made a fresh installtion of rtems-tools 4.10 from source for powerpc on debian lenny 5.0.4.
> From the cvs i have loaded the rtems-4.9.4.
> I could the hello_world test file. But still run into "Illegal Instruction" when i start hello.ralf
> as i mentioned in my last mail:
> Network Boot File load in progress... To abort hit<BREAK>
> Bytes Received =&2524435, Bytes Loaded =&2524435
> Bytes/Second =&841478, Elapsed Time =3 Second(s)
> Exception: Program (Illegal Instruction)
> SRR0 =001F0000 SRR1 =00083040 Vector-Offset =00700
> The cpu board i use have 64 Mbyte of memory installed. Have i to modify mvme2100.cfg, linkcmds ?
> Will the mvme3100 - board run with RTEMS? I would buy such kind of boards if i can not get the mvme2100
> to run in the next two month ...
> Regards,
> Heinz
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100608/432d5f62/attachment.html>
