rtems with matlab autocode problems
João Rasta freakforever at gmail.com
Wed Jun 16 15:38:34 UTC 2010
Hi,
I'm having trouble running an rtems application that uses code generated
from matlab using autocode. It all goes well until a function of this
library is called: printfs return awkward characters and then the
application crashes.
1) Is there any obvious reason to why printfs of the autocode generated
functions are not working properly? They are compiled with sparc-rtems-gcc,
as the main code.
2) Are there any special flags needed to be passed to the compiler in order
to link other libraries? Or some rtems configuration..
Best,
JM
URL: <http://lists.rtems.org/pipermail/users/attachments/20100616/60c03838/attachment.html>
