rtems with matlab autocode problems
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Jun 16 15:42:43 UTC 2010
On 06/16/2010 10:38 AM, João Rasta wrote:
> Hi,
> I'm having trouble running an rtems application that uses code
> generated from matlab using autocode. It all goes well until a
> function of this library is called: printfs return awkward characters
> and then the application crashes.
I have seen references to this before. Is this hard to do? Are there
instructions?
Standard glue code, etc.
> 1) Is there any obvious reason to why printfs of the autocode
> generated functions are not working properly? They are compiled with
> sparc-rtems-gcc, as the main code.
> 2) Are there any special flags needed to be passed to the compiler in
> order to link other libraries? Or some rtems configuration..
Is there any chance it is printing floating point numbers from a non-FP
task?
> Best,
> JM
Joel Sherrill, Ph.D. Director of Research& Development
