can't boot mvme2100/mvme2304
Till Straumann
strauman at slac.stanford.edu
Thu Jun 3 13:00:26 UTC 2010
If you are testing RTEMS 4.9 or newer then you need to
boot 'hello.ralf', not 'hello.exe'.
HTH
-- Till
On 06/03/2010 07:47 AM, Heinz Junkes wrote:
> Hi,
> I am new to RTEMS. Up to now i have worked with VxWorks and will use RTEMS in future.
> I have a couple of mvme-CPU-boards and to get experiences with the development process
> of RTEMS i tried to get RTEMS running on this type of boards.
> Unfortunately i run into "Illegal Instruction" calls when it try to run the test-programms like "hello.exe"
> PPC5-Bug>nbo
> Network Booting from: DEC21143, Controller 0, Device 0
> Device Name: /pci at fec00000/pci1011,19 at e,0:0,0
> Loading: hello.exe
> Client IP Address = 141.14.128.21
> Server IP Address = 141.14.131.168
> Gateway IP Address = 141.14.128.128
> Subnet IP Address Mask = 255.255.240.0
> Boot File Name = hello.exe
> Argument File Name =
> Network Boot File load in progress... To abort hit<BREAK>
> Bytes Received =&2524435, Bytes Loaded =&2524435
> Bytes/Second =&841478, Elapsed Time =3 Second(s)
> Exception: Program (Illegal Instruction)
> SRR0 =001F0000 SRR1 =00083040 Vector-Offset =00700
> IP =001F0000 MSR =00003040 CR =00000000 FPSCR =00000000
> R0 =00000000 R1 =03F00000 R2 =00000000 R3 =00000000
> R4 =00000000 R5 =49504C01 R6 =00007000 R7 =001F0000
> R8 =03F0CF4C R9 =03F0CD4C R10 =03F0CD55 R11 =03F0CE4C
> R12 =03F0CE4C R13 =00000000 R14 =00000000 R15 =00000000
> R16 =00000000 R17 =00000000 R18 =00000000 R19 =00000000
> R20 =00000000 R21 =00000000 R22 =00000000 R23 =00000000
> R24 =00000000 R25 =00000000 R26 =00000000 R27 =00000000
> R28 =00000000 R29 =00000000 R30 =00000000 R31 =00000000
> SPR0 =BA57C814 SPR1 =00000000 SPR8 =00000000 SPR9 =00000000
> 001F0000 7F454C46 WORD $7F454C46
> I assume that it has something to do with the amount of memory. On my boards i have 64MB and more memory available.
> I think one have to use longjumps (gcc -mlongcall). I didn't found the point where i can define the used memory for my boards to get
> the right initialization.
> Any idea to overcome that problem ?
> Heinz
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100603/8fd9a88e/attachment-0001.html>
