still can't boot mvme2100
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Tue Jun  8 23:17:59 UTC 2010
On 06/08/2010 09:15 AM, Till Straumann wrote:
> Heinz.
> I just booted your 'hello.ralf' you sent me off-line on my mvme2100
> which worked fine (see below). Hence, I suspect something with
> your setup must be wrong (did you check the PReP network boot
> setting in ENV?)
Till.. It has been a long time but I remember that the settings
in PPCBug had to be just right.  Does the info here match your
board?
http://www.rtems.org/wiki/index.php/Mvme2100
--joel
> HTH
> -- Till
> PPC5-Bug>nbo
> Network Booting from: DEC21143, Controller 0, Device 0
> Device Name: /pci at fec00000/pci1011,19 at e,0:0,0
> Loading: Operating System
> Client IP Address      = 134.79.33.137
> Server IP Address      = 134.79.33.86
> Gateway IP Address     = 0.0.0.0
> Subnet IP Address Mask = 255.255.252.0
> Boot File Name         = hello.ralf
> Argument File Name     =
> Network Boot File load in progress... To abort hit <BREAK>
> Bytes Received =&175944, Bytes Loaded =&175944
> Bytes/Second   =&175944, Elapsed Time =1 Second(s)
> Residual-Data Located at: $01F5511C
> Model: 0                          (e2)
> Serial: MOT06B6D26
> Processor/Bus frequencies (Hz): 199998720/66666240
> Time Base Divisor: 4000
> Memory Size: 2000000
> PCI: Probing PCI hardware
> RTEMS 4.x/PPC load:
> Uncompressing the kernel...
> done
> Now booting...
> Welcome to rtems-4.9.99.0(PowerPC/Generic (classic FPU)/mvme2100) on
> MVME 2100
> pci : Configuring interrupt routing for 'MVME 2100'
> pci : Device 0:0x00:0 routed to interrupt_line 16
> pci : Device 0:0x0D:0 routed to interrupt_line 23
> pci : Device 0:0x0E:0 routed to interrupt_line 17
> Cleared PCI errors: pci_stat was 0x20A0
> WARNING: unable to allocate page table, keeping DBAT0
> WARNING: unable to setup page tables VME bridge must share PCI space
> OpenPIC Version 1.2 (1 CPUs and 24 IRQ sources) at 0xFCE40000
> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 1
> Overriding NumSources (24) from configuration with 16
> OpenPIC timer frequency is 8333216 Hz
> Universe II PCI-VME bridge detected at 0xFCDFF000, IRQ 23
> Universe Master Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
> 1:    0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
> 2:    0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
> Universe Slave Ports:
> 0:    0xC0000000 0x02000000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> *** HELLO WORLD TEST ***
> Hello World
> *** END OF HELLO WORLD TEST ***
> On 06/08/2010 07:49 AM, Heinz Junkes wrote:
>> Hi,
>> i have now made a fresh installtion of  rtems-tools 4.10 from source for powerpc on debian lenny 5.0.4.
>>  From the cvs i have loaded the rtems-4.9.4.
>> I could the hello_world test file. But still run into "Illegal Instruction" when i start hello.ralf
>> as i mentioned in my last mail:
>>   Network Boot File load in progress... To abort hit<BREAK>
>>   Bytes Received =&2524435, Bytes Loaded =&2524435
>>   Bytes/Second   =&841478, Elapsed Time =3 Second(s)
>>   Exception: Program (Illegal Instruction)
>>   SRR0 =001F0000 SRR1 =00083040 Vector-Offset =00700
>> The cpu board i use have 64 Mbyte of memory installed. Have i to modify mvme2100.cfg, linkcmds ?
>> Will  the mvme3100 - board run with RTEMS? I would buy such kind of boards if i can not get the mvme2100
>> to run in the next two month ...
>> Regards,
>> Heinz
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
