about autoconf >= 2.64
pierre kestener pierre.kestener at cea.fr
Tue Mar 2 16:58:25 UTC 2010
Hello,
While upgrading from Ubuntu 9.04 to Ubuntu 9.10, autoconf was updated
from 2.63 to 2.64, and I noticed that some of the configure script are
not well generated anymore in RTEMS source tree.
For example, the generated cpukit/configure contains the following piece
of code (bad shell code):
if test x"${enable_rtems_debug}" = x"yes"
cat >>confdefs.h <<_ACEOF
#define RTEMS_DEBUG 1
_ACEOF
; then :
fi
Falling back to "old" autoconf 2.63, everything works perfectly on
Ubuntu 9.10
I also tried autoconf 2.65, the bug is still there.
I was wondering if such a bug was Ubuntu-specific, and if someone was
using autoconf >=2.64 with success and on which distribution ?
Thank you.
Pierre Kestener.
