Simple Line Editor
Till Straumann
strauman at slac.stanford.edu
Tue Mar 2 15:59:08 UTC 2010
Eric Norum wrote:
> This looks like an interesting project. As the web page says,
> functionality somewhat like readline would be very useful.
> The one big requirement is that the code be reentrant to allow for
> multiple ssh or telnet 'logins' to the RTEMS machine. This is
> currently the major shortcoming in readline (and the similar 'tecla'
> project) since they rely on the termcap library which is non-reentrant.
You can build 'tecla' without using curses, ncurses or termcap and you get a
very nice, re-entrant line editor (assumes/supports an ANSI terminal only).
FWIW
-- Till
> A way to limit the scope to make the project more tractable would be
> to support only the ANSI terminal control sequences. This isn't that
> big a restriction nowadays when a 'terminal' is likely an emulation
> program running on another computer.
> On Feb 20, 2010, at 8:22 AM, Gokul Sudhakaran wrote:
>> Hi
>> I recently installed rtems on my system and have been browsing
>> through some of the open projects in the rtems wiki pages. I am
>> interested in implementing the Simple Line Editor project.
>> (http://www.rtems.com/wiki/index.php/SimpleLineEditor).
>> I would appreciate it if someone could help me in getting a clear
>> idea about the problem, any examples or sites that i could refer.
>> Regards
>> Gokul
>> rtems-users mailing list
>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> http://www.rtems.org/mailman/listinfo/rtems-users
> Eric Norum
> wenorum at lbl.gov <mailto:wenorum at lbl.gov>
