Simple Line Editor
Wed Mar 3 23:01:20 UTC 2010
Joel Sherrill wrote:
> Could the current GSOC project have a second phase to implement
> the alternate use of tecla?
> I am just thinking since this project is primarily refactoring and
> documenting the existing line editor, it shouldn't add a lot of work
> to be able to use an alternate "line entry" system.
The existing project is not big if you support the functionality that
currently exists. I think creating an interface and then supporting a couple
of line editors is starting to be a GSoC sized project.
> And one could
> be a very simple fgets() which would be no history, no real editing,
> etc.  Even lighter.
Yes we should provide a very basic one. It could call the BSP polled input, ie
the input version of printk. The current shell could also be broken down into
parts so you can have a very simple helpless ability to execute some commands
in low memory targets as well as splitting up the scripting support.
> So at the end, we would have shell with support for multiple
> line entry subsystems and a way to configure them.
Yes.
