about autoconf >= 2.64
pierre kestener
pierre.kestener at cea.fr
Thu Mar 4 08:55:43 UTC 2010
Hi Daniel,
Thanks for correcting this, but finally wouldn't it be better to
distribute a patch against CVS with your modifications instead of an
entire tree. This would ease finding bugs and probably improve your work ?
Pierre.
Daniel Hellstrom a écrit :
> Hi Pierre,
> pierre kestener wrote:
>> Thanks to all for your answers, I found the origin of the bug.
>> I was testing Gaisler's RTEMS sources
>> (rtems-4.10-1.1.99.10-src.tar.bz2); these sources are based on rtems
>> cvs before Ralf commit on file cpukit/aclocal/check-rtems-debug.m4
>> (Add missing ','.).
> Yes, the problem is that this patch is missing. I havn't synced
> against the official 4.10 branch for quite some time now (for too
> long), I will try to resync for next release.
>> As autoconf >= 2.64 is better than old versions, it do not let it
>> pass this bug !!
>> By correcting this bug, everything works well whatever autoconf
>> version on Ubuntu 9.10.
>> My advice to people using Gaisler's sources along with autoconf >=
>> 2.64, is to temporaly fall back to autoconf 2.63, or correct the
>> check-rtems-debug.m4 bug.
> I have updated the source release at the gaisler server with this
> patch, the new version is named rtems-4.10-1.1.99.10a-src.tar.bz2.
> Thanks,
> Daniel
>> Pierre.
>> Joel Sherrill a écrit :
>>> On 03/02/2010 10:58 AM, pierre kestener wrote:
>>>> Hello,
>>>> While upgrading from Ubuntu 9.04 to Ubuntu 9.10, autoconf was updated
>>>> from 2.63 to 2.64, and I noticed that some of the configure script are
>>>> not well generated anymore in RTEMS source tree.
>>> The autoconf version is tied to the RTEMS version. For
>>> hosts we provide binaries on, automake/autoconf is included
>>> in the RTEMS toolset. Updating autotools can break things
>>> so we tend not to update it on release branches. You can see
>>> this by the latest (or terminal) autoconf RPM for each release
>>> branch.
>>> rtems-4.6-autoconf-rtems-2.59-0.noarch
>>> rtems-4.7-autoconf-2.60-4.el5.noarch
>>> rtems-4.8-autoconf-2.61-7.el5.noarch
>>> rtems-4.9-autoconf-2.62-4.fc12.noarch
>>> rtems-4.10-autoconf-2.65-1.fc12.noarch
>>>> For example, the generated cpukit/configure contains the following
>>>> piece
>>>> of code (bad shell code):
>>>> if test x"${enable_rtems_debug}" = x"yes"
>>>> cat>>confdefs.h<<_ACEOF
>>>> #define RTEMS_DEBUG 1
>>>> _ACEOF
>>>> ; then :
>>>> fi
>>>> Falling back to "old" autoconf 2.63, everything works perfectly on
>>>> Ubuntu 9.10
>>>> I also tried autoconf 2.65, the bug is still there.
>>>> I was wondering if such a bug was Ubuntu-specific, and if someone was
>>>> using autoconf>=2.64 with success and on which distribution ?
>>>> Thank you.
>>>> Pierre Kestener.
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
Pierre KESTENER - Ingénieur-Chercheur
CEA Saclay -- DSM/IRFU/SEDI/TRAPS
91191 Gif-sur-Yvette - FRANCE
tel : +33 (0)1 69 08 57 09
fax : +33 (0)1 69 08 31 47
http://pierre.kestener.org/
