Test Version of new RTEMS Web Site
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 5 16:15:51 UTC 2010
On 03/05/2010 09:53 AM, Gokul Sudhakaran wrote:
> Hi
> The test site looks much better than the original, nice work.
> I think enabling the search module will be of great help.
I will enable it but there isn't much content to search. Mostly it
is links to other sub-areas of RTEMS. Maybe Chris can create a
custom Block which is the google search of rtems.org like we
had on the old site.
Chris.. can it go on the upper right and use some of that dead
green space?
> Also the home tab is missing
What is a home tab? Do you mean that the left most item on
the primary menu (horizontal at top under logo) should have a
Home as the first item.
> clean urls should be enabled,
This requires URL rewriting so I was waiting until
we got to the production server.
> it looks better without the question marks in the url :)
I agree. We did this in the wiki. :)
> I hope this helps!!
All feedback helps. Thanks.
--joel
> On Fri, Mar 5, 2010 at 6:36 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 03/05/2010 06:20 AM, Aanjhan R wrote:
> On Thu, Mar 4, 2010 at 3:43 PM, Joel
> Sherrill<joel.sherrill at oarcorp.com
> Feedback and comments are appreciated.
> 1. Why not make the wiki also in similar theme?
> Chris is handling style issues so he will have to comment.
> My main one is that the wiki uses a different style sheet
> and would have to be hand-crafted individually. But if
> Chris is willing, it is a good idea.
> 2. The news updates below on the main page can have a clear
> distinction between the posts. Something like a box for every news
> update. Will look prettier and more readable.
> Again.. style issue.
> I also meant to ask if it was possible to not use a separate
> line for the date. Or at least put the date below the news
> item.
> 3. Content wise it is neat and well organised in my opinion.
> Though we
> might want to do a test run on someone who is unfamiliar with
> RTEMS
> site and looking for some info. Best people - New incoming
> GSoC 2010
> candidates.
> Yes. That's the ultimate goal. Is it easier to find things for
> a newbie.
> Great work!
> Thanks.
> I think I will get Jeff to help me install the rewrite rules
> on rtems.org <http://rtems.org> today so we can move this over. I
> think it is
> close enough to just move it when that is done.
> --joel
> Regards,
> Aanjhan
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> Regards
> Gokul
Joel Sherrill, Ph.D. Director of Research& Development
