Eclipse compiler settings
Johannes Schock
j.schock at stiefelgmbh.de
Thu Mar 25 10:46:58 UTC 2010
Problem solved,
I mixed the two Wiki pages RTEMS_Eclipse_Plug-in and
Initial_RTEMS_Eclipse_Plug-in, which made the configuration a mess.
Mit freundlichen Grüßen
Johannes Schock
Stiefel GmbH
Allmend 7/2
75038 Oberderdingen
Webseite: www.stiefelgmbh.de
> Hello,
> I currently try to get Eclipse for RTEMS running on my Fedora12.
> The RTEMS toolchain I'm using is the ARM-4.10 because I like to try the
> lpc24xx_ea BSP (I have a board here).
> The problem is:
> The compiler settings of eclipse point to "/opt/rtems-4.10/bin/g++"
> but should point to "/opt/rtems-4.10/bin/arm-rtems4.10-g++"
> When I try to change the settings in Project/Properties they aren't
> persistent: I change the path, press Apply, and after changing the Tab, >
> the
> old setting is back. Renaming the compilers should help, but this isn't a
> "nice" solution.
> I'm sure the problem sits in front of the Computer, but I can't proceed
> without help.
> Johannes Schock
> Stiefel GmbH
> Allmend 7/2
> 75038 Oberderdingen
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
