Building the newest RTEMS error: Invalid BSP
smy smygsoc at gmail.com
Mon Mar 29 12:58:06 UTC 2010
Thank you for replying. :)
My steps are:
1. cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co
-rrtems-x-y-branch rtems
  cd rtems
  ./bootstrap
2. mkdir rtems-build
  cd rtems-build
  ../rtems/configure --target=sparc-rtems -enable-rtemsbsp=sis
--enable-test=samples --disable-posix --disable-itron
--prefix=/home/smy/sparc-rtems
3. make && make install
configure: error: Invalid BSP
configure: error:
../../../../../../../rtems/c/src/lib/libbsp/sparc/configure failed for
lib/libbsp/sparc
make[2]: *** [sis] Error 1
make[2]: Leaving directory `/home/smy/toolchain/rtems-build/sparc-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/smy/toolchain/rtems-build/sparc-rtems/c'
make: *** [all-recursive] Error 1
Besides, the 'uname -a' result is 'Linux mort-desktop 2.6.24-26-generic #1
SMP Tue Dec 1 18:37:31 UTC 2009 i686 GNU/Linux'
and
PATH='/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/smy/sparc-bin/bin'
where /home/smy/sparc-bin/bin contains the binutils and cross-compiler.
URL: <http://lists.rtems.org/pipermail/users/attachments/20100329/1bfbaad8/attachment-0001.html>
