Building the newest RTEMS error: Invalid BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Mar 29 13:14:57 UTC 2010
On 03/29/2010 07:44 AM, smy wrote:
>> You lost steps in the configure process somewhere. Every
>> BSP is built every day now. Plus you are looking at 4.9.4.
>> We will need more information to help you. What host,
>> configure command, "echo $PATH", etc. You just said
>> "it's broken" and we can't see your screen.
>> FWIW you need to build the CVS head as part of the
>> GSoC Getting Started but since you have started
>> with 4.9.4, let's finish that first.
>> --joel
> Thank you for replying. :)
> My steps are:
> 1. cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co
> -rrtems-x-y-branch rtems
> cd rtems
> ./bootstrap
What version of autoconf and automake do you have?
RTEMS has to be bootstrapped with the right versions.
4.9 uses these
-bash-4.0$ rpm -qf /opt/rtems-4.9/bin/autoconf
rtems-4.9-autoconf-2.62-4.fc12.noarch
-bash-4.0$ rpm -qf /opt/rtems-4.9/bin/automake
rtems-4.9-automake-1.10.3-1.fc12.noarch
It doesn't look like either has any patches.
> 2. mkdir rtems-build
> cd rtems-build
> ../rtems/configure --target=sparc-rtems -enable-rtemsbsp=sis
> --enable-test=samples --disable-posix --disable-itron
> --prefix=/home/smy/sparc-rtems
Since you built your own tools, did you apply the patches
in contrib/crossrpms/patches? What --target did you use
on the tool configure. The expected target here is:
--target=sparc-rtems4.9
> 3. make&& make install
> configure: error: Invalid BSP
> configure: error:
> ../../../../../../../rtems/c/src/lib/libbsp/sparc/configure failed for
> lib/libbsp/sparc
> make[2]: *** [sis] Error 1
> make[2]: Leaving directory `/home/smy/toolchain/rtems-build/sparc-rtems/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/smy/toolchain/rtems-build/sparc-rtems/c'
> make: *** [all-recursive] Error 1
> Besides, the 'uname -a' result is 'Linux mort-desktop 2.6.24-26-generic
> #1 SMP Tue Dec 1 18:37:31 UTC 2009 i686 GNU/Linux'
> and
> PATH='/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/smy/sparc-bin/bin'
> where /home/smy/sparc-bin/bin contains the binutils and cross-compiler.
What distribution is this? Obviously you built your
own tools.
This looks suspiciously like a bootstrap and autotools
version issue.
Joel Sherrill, Ph.D. Director of Research& Development
