Building the newest RTEMS error: Invalid BSP
alin rus
alin.codejunkie at gmail.com
Mon Mar 29 14:01:16 UTC 2010
On Mon, Mar 29, 2010 at 4:24 PM, smy <smygsoc at gmail.com> wrote:
> oh. My distribution is ubuntu 8.04. And I build the toolchain without the version number, like 'sparc-rtems-gcc', so I configure target=sparc-rtems.
> 2010/3/29 Aanjhan R <aanjhan at gmail.com>
>> On Mon, Mar 29, 2010 at 2:58 PM, smy <smygsoc at gmail.com> wrote:
>> > 2. mkdir rtems-build
>> > cd rtems-build
>> > ../rtems/configure --target=sparc-rtems -enable-rtemsbsp=sis
>> > --enable-test=samples --disable-posix --disable-itron
>> > --prefix=/home/smy/sparc-rtems
>> I think it should be --target=sparc-rtems4.9
>> A
> rtems-users mailing list
> rtems-users at rtems.org
Here's a guide to build the toolchain but the target is set to powerpc
just use sparc instead
http://wiki.rtems.org/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu
then you should continue phase 3 from here
http://wiki.rtems.org/wiki/index.php/Quick_Start
