Calling rtems_io_lookup_name from within an ISR
Jamie Bowman
jamie.bowman at steepestascent.com
Tue May 11 16:01:52 UTC 2010
Hopefully this should be quite an easy one. Within the RTEMS Documentation
"c_user" it states that the following is a list of RTEMS system calls that
may be made from an ISR:
* IO Management
The following services are safe to call from an ISR if and only if the
device driver service invoked is also safe. The IO Manager itself is safe
but the invoked driver entry point may or may not be. rtems_io_initialize,
rtems_io_open, rtems_io_close, rtems_io_read, rtems_io_write, rtems_io_
control
Is it safe to call an rtems_io_lookup_name from within an ISR?
Kind regards
Jamie
URL: <http://lists.rtems.org/pipermail/users/attachments/20100511/29639b68/attachment.html>
